Box help
Username: Crappycarguy
Post Number: 8
Im looking for a box for two 12.1 perfects they are recomended to have 1 cubic feet in sealed but the closest i can find is .88 would that be ok?
ThatGuyYouKnow
I know what you mean 1 cuft box's are really hard to find for 12's, I found a website...
http://www.atenclosures.com/
that has em but no idea how to order from them, too lazy to email or call so maybe you could get it a try...
if anybody else has a site with 1 cuft enclosers pls resond to this
Username: Insearchofbass
Post Number: 395
if you stuff that box (.88) with 2 lbs poly fill or 2 inches fiberglass youll have 1.06 cf. before subwoofer displacement
Username: Iamduff_87
Michigan America!
Post Number: 240
if you have a local shop that sells ALpine they might have them. I guess the one here sells 1cu ft boxes for thier 12" Type Rs. THey run abotu $40 I think. COuld prolly build one for 1/2 price.
Username: Sas
Post Number: 10
why not build a box? i have 2 infinity 12.1d's, i am fixing to build the box in just a few mins, the cost is $20 for wood and a couple hours of relaxation
