Bronze Member Username: Nysteelers
Post Number: 44 Registered: Aug-04
Posted on what would be a good amp for 2 12' kicker solobaric L5's? it is going in my SUV. would the jbl 600.1 be good u think? |
Johnathan Unregistered guest |
Posted on yes if subs are 2 ohm wired in parralell |
Post Number: 45 Registered: Aug-04
Posted on ok thanks...what if they are 4 ohm though? what would you recommend i get, and im tryiung 2 keep this as inexpensive as possible |
Posted on jbl 1200.1 |
Post Number: 46 Registered: Aug-04
Posted on thanks |
Posted on no worries dude |
Bronze Member Username: Allpro
Dacula,
Ga
United States
Post Number: 14 Registered: Sep-04
Posted on JBL 1200.1 inexpensive?????? Mike, what is your budget and will your subs be sealed or ported? |
