Bronze Member Username: LostrookieNew Castle, PA United States Post Number: 11 Registered: Aug-04 | I duno wanna waste my money and get the wrong amp for these subs so i need major help cuz im clueless lol.. which amp would i get full power and would work perfectly with 3 JL 10w3 v2s 4 ohm version (300 W each). I dont even know if i would need a mono, 2-channel,4-channel or what. Would any of these amps be compatable with these subs? if not does anyone know any that arent too pricey? this guy i know told me i might need this one but i wasnt sure about it b/c of the RMS and everything-->http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39735&item=5718662829&rd= 1&ssPageName=WDVW http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64572&item=5718170282&rd= 1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39737&item=5718530578&rd= 1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39737&item=5718455262&rd= 1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39737&item=5719012437&rd= 1#ebayphotohosting |
Anonymous | Need some help here!! I have a ford f-250 superduty crew cab truck and I'm looking to add subs. All I've found to fit in my truck are 8" subs. I've been looking at the Audiobahn ALUM8P dual 6 ohm subs. I was wondering if anyone new how they sounded and how to hook them up. Basically what would be the best amp to run these little guys? |
Visitor#78 Unregistered guest | Lost: If you want to run all three, you need to find an amp that will run about 1000w RMS mono @ 1ohm Unfortunately none of those amps are going to work. You need to look at a few of these: Hifonics BX100D $230 Shipped http://www.ikesound.com/product-product_id/1506 JBL BP1200.1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5718562617&rd= 1&ssPageName=WDVW Kicker KX1200.1 $400 shipped http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5718683557&rd= 1#ShippingPayment Good Luck Anon: www.proboxrocks.com any several other companies make special boxes for 10s and sometimes 12s for your truck. Check them out and also ebay. AVOID AUDIOBAHN at ALL costs |
Bronze Member Username: LostrookieNew Castle, PA United States Post Number: 12 Registered: Aug-04 | thanks my man |
Bronze Member Username: LostrookieNew Castle, PA United States Post Number: 13 Registered: Aug-04 | anymore suggestions? |
