New member Username: Jarryd2018Post Number: 1 Registered: Sep-04 | i have a 98 explorer and i want to build a box for 2 12" subs and 1 15" sub i dont really kno if i need to go with ported or sealed email me if u kno of any plans for me to use Freestylin111@aol.com |
Silver Member Username: InvainMichigan United States Post Number: 117 Registered: Aug-04 | it depends on what you want, more spl or more sq |
Silver Member Username: JayjLouisiana USA Post Number: 495 Registered: May-04 | All you got to do is surf the net for building plans. Look at this site for starters then look for good plans but they are going to cost you. http://www.crutchfieldadvisor.com/S-Bfv4pW79l8o/reviews/20030701/build_box.html |
New member Username: Jarryd2018Post Number: 2 Registered: Sep-04 | i want to have good spl but i also want good sound quality i dont want it to sound like crap and just be a bunch of noise |
New member Username: Jarryd2018Post Number: 3 Registered: Sep-04 | the subs i have r 2 mtx t5512 and 1 mtx t5515 and i have no idea what kinda box to use i want good spl but i also want it to have good sq |
New member Username: Jarryd2018Post Number: 4 Registered: Sep-04 | i mainly want it to be good sound quality it will be loud enough either way |
New member Username: Jarryd2018Post Number: 5 Registered: Sep-04 | wats the best box for sq for 2 12" subs and a 15" sub i dont kno if i need ported or sealed or how big to make it give me some ideas on how i shoud set this up |
Silver Member Username: SouthernrebelLouisiana USA Post Number: 140 Registered: Mar-04 | an AP enclosure would have the best SQ....but they are harder to build (you have to have the rite stuff) i would say sealed...but mixing sub sizes usually decreases SQ. |
New member Username: Jarryd2018Post Number: 6 Registered: Sep-04 | whats an AP enclosure |
