Anonymous | whats the best amp for two audiobahn 1206t please help |
Silver Member Username: SymplestilesStockton, CA Usa Post Number: 103 Registered: Aug-04 | whats your price range? audiobahn tends to need a ton of power to hit at all so it could be a little more expensive than with some higher grade subs. also what are that models rating? |
Anonymous | there 1100 watts rms a piece andill be willing to spend $300 |
Anonymous | i hava audiobahn amp layin around in my closet would you be interested? its model number is a1500hcq. that sub is good with this amp. a dual 4 ohm sub requires 2 or 8 ohms. this amp puts out 1000 w rms at 2 ohms. and 2000 w rms at 1 ohm. so if you wanted another 1206t in the future you could still use this amp. i need to make sure if it works or not im gettin my brahma in on tuesday and ill test it. if it works would you be interested? ill let it go for 250 plus shipping. thanks email me at bumpin_brahma_06@hotmail.com |
Anonymous | sry didn't know u have 2. never mind the statment bout gettin one in the future. 2 of those subs would work on the amp i have still though. it would put out 2000 rms @ 1 ohm. thanks |
