Cerwin vega vmax 15 box size
Username: Heavyb
Hopkins, Sc Usa
Post Number: 74
what box size would i need for a 15 vmax. also recomend loud but good sounding tuning frequencies
Username: Heavyb
Hopkins, Sc Usa
Post Number: 75
this is for a ported box
Username: Sploosh56
Post Number: 383
how much space do you have to work with? what vehicle are you installing this sub in?
Username: Blindc1rca
Post Number: 106
same question with a vw golf (loootttts of trunk space)
Username: Sploosh56
Post Number: 384
I'd go with something like 4 - 5 cuft tuned to about 33 hz
Username: Heavyb
Hopkins, Sc Usa
Post Number: 76
i have a pathfinder and want 2. would something like 3 cubic ft a peice tuned to 33 hz work or do i need more space.
Post Number: 115
4-5 cu. ft at 33hz would be optimal? i would like to conserve trunk space a little, how would 3.4 cu. feet be tuned to 33? would it be a big diff from 4-5 cu. ft?
Post Number: 116
btw blare holz since you have a pathfinder you should probably go with the same advice they are giving me, both hatchbacked cars with open air throughout the car, so optimal in mine would be near optimal in yours.
Username: Sploosh56
Post Number: 387
3.4 would work too.
Username: Heavyb
Hopkins, Sc Usa
Post Number: 77
what is the dispalcement of a 15 vmax i need to know to build my box and i cant find it anywhere
Username: Symplestiles
Stockton, CA Usa
Post Number: 112
the displacement for the 15" vmax is .22cuft/6.21 (straight off the spec sheet)
