Sound dampening material??
Username: Symplestiles
Stockton, CA Usa
Post Number: 115
hey i was wondering whats the best alternative to dynamat..and whats the main difference between the two? i just dont get how one product can be twice as much as the other yet do the same thing. ive heard of fatmat, b-quiet, eDead, ice mat..etc. what do you guys suggest? im in a 91' reg cab pickup so i dont have a truck or anything, just looking to keep some sound in and stop all the rattling. suggestions + links to buy them from? thanks
Username: Jmloughrey
Farmington, CT
Post Number: 270
just had over to lowes or home depot (i know gratuitus plug) and buy some water barrier that you would stick on a roof before you roof it...not the tar stuff, its like a mat of insulation...forget the exact name...someone else hsould responce with it shortly...
Username: Invain
Michigan United States
Post Number: 99
It's called Icee, or iceaway, something with ice in it. One side of it is silver and it says the name of it all over it.
Username: Invain
Post Number: 102
Ice Guard, that's what it is.
