Hook me up witha amp
insearchofagoodamp
hey im looking for a decent amp that produces 700-1000 watts either at 1 ohm or 4 ohms (for a dual 2) my budget is rather low. probly around 150-225 US dollars.
Username: Koz1031
Monticello, In United states
Post Number: 67
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7917785070&ca tegory=38638
try this one, it's MUCH better for your money than Lanzar, Lanzar really suck ball
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5718163568&rd= 1
Username: Caraudiofng
Houston, TX
Post Number: 217
Yeah, Anon has the better suggestion. Not a bad amp for the money.
Username: Southernrebel
Louisiana USA
Post Number: 129
dont even think about the lanzar....or boss, or pyle, or anything like that!!!
they crap...just read some of the threads on here about them!
the Hifonics isnt bad...that is a good price too.
insearchofagoodamp
k yeah i was either thinkin of the hifonics nx750 or the hifonics bx1000d. either will work i guess o yeah its goin on a brahma 15" in a ported box. which one would you suggest the nx750 or the bx1000d?
Louisiana USA
Post Number: 132
the BX1000D...
the 1000D as well, what size is your ported box?
SIZE GOES MATTER!! lol well, actually the bigger the box you have the less power is needed to run the subwoofer.
Username: Dodge
what amp or watt's
should i get for 2 12 massive subs
