I bought ONKEYO TX-SR601 and I am considering buying new speaker system. I am considering HSUResearch VT-12/STF1, Onix Rocket Tykes 5.1, and Athena Mecra 6. The Living room is 16 by 14. I would appreciate if someone can compare or recommend one of these system.
Definitely the HSU and Rockets, much better than the Micras.
Beth
Thanks Berny. Do you know which one of (HSU or Rockets) matches better with TX-SR601? Also, if you would compare them or recommend one of sustems? I will use the system for music and movies(50/50)%. Thanks
