Bronze Member Username: NysteelersPost Number: 33 Registered: Aug-04 | i have a 96 pathfinder and am looking to buy 2 12" cerwin vega vmaxes. Im planning to hook them up to a jbl 600.1. Do i buy the SVC or DVC, and whats the difference?? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13949 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13950 |
Bronze Member Username: NysteelersPost Number: 34 Registered: Aug-04 | oops sry i posted this in the wrong place |
Silver Member Username: CaraudiofngHouston, TX Post Number: 235 Registered: Aug-04 | To keep the Amp more efficient and cooler, get the 2 SVC 40hm subs. That will put a 2ohm load on the amp, and put 300w a piece to the subs. |
Bronze Member Username: NysteelersPost Number: 36 Registered: Aug-04 | ok tnx |
Silver Member Username: Davids2004Houston, TX USA Post Number: 704 Registered: Jun-04 | either two svc 4 ohm or two dvc 2 ohm. Either one will give you a 2 ohm load on the amp. |
