Anonymous | Yea,I've been looking around on here lately at what subs are what. If I wanted to buy a 12" sub for SQ,Sealed,BUT still wanna POUND,what are my TOP 3 picks? Lets say money dont matter,even though it does. Im thinking: 1. 12W7 JL Audio 2. 12" RE X.X.X. 3. 12" ?????? |
Gold Member Username: Jonathan_fGA USA Post Number: 1488 Registered: May-04 | Personally, I'd X out the W7 and go with the X.X.X., ID Max, and Eclipse Titanium. All fantastic subs. Your choices may be totally different, though. |
Bronze Member Username: Tom_kPost Number: 17 Registered: Jul-04 | Well,thats just it. I wanted to see what you all thought of what I should get? Is the W7 that over-priced? I've got a 12WO,and considering thats their worst woofer,I couldn't imagine what the W7 would sound like. But if I can get a X.X.X. that is at least = to the W7 in all categories,for cheaper,I'd obviously do that. Thanks |
Bronze Member Username: Mike_anthesCanton, SD USA Post Number: 17 Registered: Aug-04 | Adire audio and Resonant Engineering are better than jl and cheaper too. if i were you i would also look into a adire audio brahma. www.adireaudio.com |
Anonymous | Alright,thanks. |
Bronze Member Username: Slap_johnsonArizona Post Number: 35 Registered: Aug-04 | 2 12" id max for all out sq |
