Bronze Member Username: Mike_anthesCanton, SD USA Post Number: 14 Registered: Aug-04 | hey im wondering where i can get carpet for my sub box. the cheaper the better. also what kind of glue or adhesive r u supposed to use? thanks guys. |
Bronze Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 30 Registered: Aug-04 | cardomain.com |
Bronze Member Username: Mike_anthesCanton, SD USA Post Number: 15 Registered: Aug-04 | i kinda want to get it at a local store. walmart? menards? etc. |
Bronze Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 32 Registered: Aug-04 | I couldnt find any at walmart or moblie one. |
Bronze Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 33 Registered: Aug-04 | Hey do u know where i can find RE subs on the web? |
Bronze Member Username: Cb9869Post Number: 12 Registered: Jul-04 | www.reaudio.com |
New member Username: BlueviperMaryland United States Post Number: 1 Registered: Sep-04 | I need help in choosing a box for my sub, it's a 150 watts rms, 10" lightning audio. 300 watts max, and i have a 300 watt max single channel amp powering it, and it's in a sealed enclosure, i dunno if i should get a ported or bandpass enclosure. thnx |
Bronze Member Username: Koz1031Monticello, In United states Post Number: 82 Registered: Jul-04 | try a local fabric shop. It's a long shot, but we have 1 that carries it, maybe you do also. And remember it doesn't have to be done in carpet, you can cover then in anything, be creative and unique. |
Silver Member Username: Davids2004Houston, TX USA Post Number: 711 Registered: Jun-04 | try a hardware store. |
Silver Member Username: SymplestilesStockton, CA Usa Post Number: 106 Registered: Aug-04 | i bet a car audio shop in your area carries it |
Silver Member Username: CaraudiofngHouston, TX Post Number: 247 Registered: Aug-04 | I got grey or black carpet cheap at Home Depot. Bad thing is, they make you but it in the width of the roll. (12 or 6 foot lengths) But it was less than $10 for all of it |
