New member Username: GinuwinepzPost Number: 2 Registered: Aug-04 | I just bought a 15" kicker comp VR...i am putting it in a 99 grand am 4 door....should i get a ported or sealed box? i want it as loud as possible, but also as deep as possible..which box is deeper and which is louder? which would you get? Also, are there any cheap ways to get rid of trunk rattle? thanks for the help!! |
Bronze Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 11 Registered: Aug-04 | go to kicker.com to get all the specs on the box for that sub |
New member Username: GinuwinepzPost Number: 3 Registered: Aug-04 | I went there....and it really did not tell me a whole lot about what which box would really sound like, the pros and cons of each. |
Silver Member Username: InsearchofbassPost Number: 197 Registered: Jun-04 | stuff for trunk rattle etc check this stuff out its cheap just read the article http://www.sounddomain.com/memberpage/337124/6 |
Silver Member Username: HiphopanonymousPost Number: 102 Registered: Dec-03 | you should go ported. just build a big nice slot ported box for that 15 and you will be bumping. i went from sealed to ported and the sq didn't dip down at all. it still sounds clean. plus, you get more spl ported. |
