Want Boomy System
i have a 1996 ford mustang gt, not much room to work w/, but i want a really loud system, i have $4000 to spend and i want to get a flip screen dvd player so if you could factor that in there i would greatly appriciate it, im looking for spl while maintaing sq but i just want this thing to bump, i want it to put 3 12" kicker solo l5 (my old system) to shame, but i need speakers, amps, subs, and wireing, and dvd flip screen i can get a box on my own
Username: Demigod33
Post Number: 108
lucky you
Username: Ctx
Post Number: 28
3,12 jl w6v2 subs
1 jl 1000/1 amp
^lots of boom there
will that even fit in my trunk? what about speakers
Get 3 RE 15s with a JL 1000/1 to all of them. That will be too loud for everyday driving, but if you want to spend all the money, go for it. This will run you at around 3500, not sure the cost of a DVD player.
Or if you want to spend less you could get by with a JL 500/1 to each of them.
Username: Jessejames
NB, PA USA
Post Number: 137
3 15's probably won't fit in a mustang trunk, but even if you did fit them... your car would proabaly shake it's self to pieces, 3 RE X.x.x 15's will hit so hard you might hurt your self.
