What is wrong
i have a mtx 1501 d and i cant turn the play with the controls on the amp with out it going crazy...i have a 4 g power wire and mtx says u should use 1/0 for it could this be the problem oris it something else
Username: Insearchofbass
Post Number: 176
what ohm subwoofers do you have hooked up to it because if you have it hooked up into two ohms you should have a thicker power wire with equal ground. I have a 0 gauge hooked to mine but when i used eight guage i just about fried it. I was in a hurry hehe.
the amp is running at 2 ohms
aight ill try that and see if it fixes the prob
