How much better are Kicker L7's thatn L5's
I have a 12 L5 (dvc 2 ohm)and i wanna know how much better the L7's are....
Would the L7 sound better in the 1.1 cu ft box i have on my current 600 watt amp of will i not be able to tell a difference, also how much difference will there be if i get an amp to match the L7????
Username: Glasswolf
Post Number: 557
L5 is for SQ. L7 is for SPL.. at least according to Kicker.
The L7 has a greater Xmax, and higher power handling.
that's about it.
if you had an S12L7 with a 1Kwatt amp, you'd probably incrase SPL by about +3dB, maybe as much as +6dB with a different enclosure.
