Peavey Power Amp For Home System
Username: Feminazi
Post Number: 19
Since I have 4 Ohm fronts and all of the rest of my speakers being 8 Ohms, I thought I should get a power amp to relieve the stress on my receiver. Would a Peavey Power Amp (old beast of one, 350 watts RMS into two 4 Ohm channels)be a wise choice? I asked my dealer and he said that it is not meant for home applications, specifically the damping factor is different.
What do you guys think? I am considering buying one because they are quite cheap!
Username: Kegger
Post Number: 24
you could try, it should not hurt anything but i'm
not sure how good it would sound not being meant to play music it probably doesn't have a very flat
frequency response.
