Anonymous | I have decided to purchase Onkyo TX-SR601 for my receiver and would like to know what's a the best speakers to match with it. I'm planning on using it for HT and music equaly. My price range is about $500.00 for the speakers. Also what subs should I consider? I've heard velodynes are good but polk seems a bit cheaper watts/$ wise.... Thank for your response in advance. |
New member Username: EdisonPost Number: 82 Registered: 12-2003 | Here is ts-xr501 real cheap (refurb). http://www.ecost.com/ecost/shop/detail.asp?dpno=157373 They also have 601 - look around for good a good deal. For speakers, try to hear these and go with one you like - you gotta like it. These are pretty good ones. Athena: http://www.bestbuy.com/site/olspage.jsp?CategoryID=cat03049&id=1051806302315&sku Id=5335979&type=product&ref=05&loc=01 Celestion: http://www.bestbuy.com/site/olspage.jsp?id=1055388007887&skuId=5632862&type=prod uct 2 sets of these: http://www.bestbuy.com/site/olspage.jsp?id=1059403841526&skuId=5855862&type=prod uct And a center: http://www.bestbuy.com/site/olspage.jsp?id=1059403858468&skuId=5856852&type=prod uct And this sub: http://www.bestbuy.com/site/olspage.jsp?id=1055388007768&skuId=5632586&type=prod uct This one is hard to hear, but is probably the best sounding - they cut out the middleman and sounds good! http://www.vertigoonline.com/Merchant2/merchant.mvc? Front m3ti Back QS4 AMMS4 center AES sub All for About $800 and it will sound even better than the above ones - I would recommend this one over others. You can read reviews on them here. http://www.axiomaudio.com/ Many audiophiles are saying it's the best deal in afforadable speakers. |
Anonymous | Axiom is a bit too high priced for my budget. However, I did looked at the pair JBL Northridge E80 series and they did sound nice. I was wondering what everyone else thinks of this model? |
New member Username: EdisonPost Number: 103 Registered: 12-2003 | Do you want just 2 speakers or 5 ? JBL is not bad but there are better. However, if you really like them, it's your toy - you got to like them - get them. If you just want 2, Athena bookshelf and a sony sub sound good at $300. |
