I have Sony Home Theater Speaker System (SAVA 500) which does not have input for coaxial/optical but it does have 5.1 challel input. My DVD player has only coaxial/optical output. Can someone suggest my how to work this out. Thanks in advance.
one of two things you can do either buy a digital processor or replace your dvd player with a new one that has 5.1 outputs.
if you buy a digital processor you probably would not use it as you upgrade later on because you won't need one as all newer systems have a digital input.
whereas if you purchase a dvd player that will work you could keep it for future upgrades.
