Unregistered guest | I have a PC with all my music on and would like to be able to play it to different rooms (not necessarily different music to each) so all I want to do is: from the PC determine which speaker set(s) will recieve the music. This way i can play throughout house, or to one room only. Without having hard-wired speaker switches it seems i could only do this with multiple sound cards and multiple amplifiers, and adjusting in control panel which output i want to use (however can't then play to all at once). I guess this will require speaker/amp sets and some kind of multiple output although i would think with wireless you could do this through frequency selection? any advice out there, or anyone trying to do (has done), the same kind of thing? |
Bronze Member Username: CarloDublin, Dublin Ireland Post Number: 12 Registered: Jun-04 | If you are going wireless Bluetooth is you answer, but at the moment if this is cost effective and how much you have in your budget is another question. This is the only other than infrared, which is worked on the principle of LINE OF SIGHT. |
Jakeanon Unregistered guest | Go here: www.medainc.com - this is THE solution! |
