Anonymous | I want to connect the spdif cable from my nexus-s card to my Yamaha RX-V2200 receiver. My connection is non-optical. There are available optical jacks but I would have to by more hardware to make this work. I would think there is a way to make this work. What are my options? Thanks |
New member Username: Xxxfubar187xxxPost Number: 2 Registered: Aug-04 | You should be able to go directly from your card SPDIF to your Coaxial input on the RX-V2400. If I'm wrong you can use a 1/8" stereo mini jack to stereo RCA converter. http://www.audioholics.com/techtips/setup/avhardware/DIY_HTPC_5.html |
