Jon | So many speaker brands out there. Just starting out its kind of hard to find your way through all of the reviews and bashings. Ha. I've spent at least 6 hours trying to research for a good powered sub for under $300. I'll find a good one and then a review will come and say it's horrible. So I came here. I hope you can give me some good recommendations for a nice home-audio sub for under $300.00 (and no higher!) Thanks in advance! |
timn8ter | http://www.creativesound.ca/details.php?model=EZSUB14DPL12 |
Jon | Out of the box please. I'm not into kit making. |
Anonymous | save your pennies for another rainy day... wait til you can afford a nice one... 450 will get you a HSU |
j0n Unregistered guest | Any other recommendations, please? I was looking at the old Sony SAWM40 but it is impossible to find nowadays. I'm sure y'all know of some cheaper ones. Stop being elitist. :p |
New member Username: Project6Post Number: 2 Registered: 12-2003 | if you like the sony, try the SAWM200 for 99.99 @ CC or the SAWX700 for 299.99 However, they also sell the Polk PSW202 for 199. which I think sounds better than the Sony. There is also the Infinity PS8BK which is the better sub for 249.99 cheers |
New member Username: EdisonPost Number: 10 Registered: 12-2003 | Buy a used hsu on www.audiogon.com or ebay. The kits are not too hard to make - and offer better quality. |
New member Username: JonmoonPost Number: 5 Registered: 12-2003 | I have a phase technology Power 8 and it works fine. I am no speaker or sub expert. Hawk has recommended this sub on previous posts. I think it is in the price range. I actually don't like too much bass and have it set up on the real low range. Just my 2 cents. |
New member Username: HeffPost Number: 26 Registered: 12-2003 | just save your money for a better sub. One nice thing about HT is you don't have to get everything right away. You can build out as your needs and budget grow. |
New member Username: Timn8terPost Number: 1 Registered: 12-2003 | http://www.hometheaterforum.com/images/svs/svsubpage.html |
New member Username: EdisonPost Number: 32 Registered: 12-2003 | http://www.vertigoonline.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AES &Category_Code=A4 |
