How can I remove the rear speaker grill on 95 maxima?
Username: Po11229
How can I remove the rear speaker grill on 95 maxima?PLEASE HELP!!!!! I need to replace the rear speaker on 95 maxima but I'm having hard time to remove the grill.
Username: Disco_stan
just start hacking away at stuff. Find some screws to unscrew and go at it. But if u r just replacing the speakers u should be able to access them inside the trunk and go from there. Eh.
check the trunk
i have a 95 integra
the screws are in the trunk to remove the grill
Username: Glasswolf
Post Number: 120
Buy the Haynes manual for your vehicle, or better yet the dealer service manual.
that will tell you how to take the entire car apart piece by piece.
