how does JBL rank for somebody who wants a system to sound ok and thump pretty good. i am thinking about 12s cause I aint got much space in my single cab pickup.
All of them are available in 12", but I don't have the depths handy. you could check their websites for this data though. JL Audio 12W0 would probably have a 7" depth as well.
ricky robinson
GlassWolf do you really think kicker is decent im not saying your wrong but i really can't trust a square speaker.
Hydro
Adire Audio shivas are probably some of the best subs to get for the price. The Kicker L7 and L5 are Exceptional subs
the elemental designs 12 inch a series will fit in my sub boxes should i get a couple ?
I agree I dislike square subs myself due to stress point issues and cone distortion at high excursion, but they are very popular subs, and good for SPL at least. I figured I'd at least suggest them. the Shivas are terrific.
will a JBL BP1200.1 amp be enough for 2 elemental design 12" subs at 750 rms watts each
depends on the model of the eD subs. the 1200.1 is 1200WRMS @ 2 Ohms. that'll be 600WRMS per sub. find the eD model sub in the size you want that will take 600 watts RMS (not max) and you're set.
the ones i want will take 750 watts rms........ is the sub too big?
get two of those subs, at 4 Ohms each, single coils. that'll present a 2 Ohm load to a JBL BP1200.1 which will be 600WRMS per sub. should work just fine.
on a scale of 1-10 how good are the ONYX LS 12.v2 subs?
