New member Username: ClvPost Number: 1 Registered: 12-2003 | I trying to put together my stereo system and I don't know too much about it. My intention is to listing music; I am not looking for home theater system. I am down to the NAD C320BEE, but I lost with the speakers I went to DMC electronics and they recommend the PSB 5T. Does anybody think this will be a good combination? Which other speakers should I consider in this price range or less? (Maybe 500 a pair). Shoul I get a 3 ways instead a 2 1/2 ways speakers? Also, what about the JBL E60, they are any good? |
New member Username: EdisonPost Number: 56 Registered: 12-2003 | Stereophile magazine recommended the first combination. You are lucky to live in Orange county close the DMC. I shop there too - they have good prices. PSB sounds better than JBL to me. You can get a refurbished 320bee for $280 there. He might even throw in cables if you buy the NAD 521 or 541 cd player. That system sounds better than stuff at typical electronic shop like circuit city, or goodguys for less money. Buy with confidence - you can't beat their value, unless you want to get used at www.audiogon.com |
New member Username: ClvPost Number: 2 Registered: 12-2003 | Thanks James, I will buy PSB and the NAD |
