JL XR vs Diamond HEX
Username: Vtecpower
which are better?
i've got JL XR525-CXi for the back of my car and Diamond Audio HEX S500s Silk Dome 5" components for the front, and a JL 300/4 amp.
Will this sound good, and is the amp power enough for the speakers?
Or Should I change the diamonds for JL XRs (or vice versa)?
What would you guys do?
(BTW - *PLEASE DON'T SUGGEST ANY OTHER BRANDS - I'M STICKING TO DIAMOND AND / OR JL ONLY*)
thanks
Username: Vtecpower
anybody? :-(
