Is Sony good? for amps?
Username: Trancein305
Hialeaj, Fl Usa
hey .i just bnought two awesome! 12" alpine type R's 1241D 4 Ohm subs. I was wondering if the sony amplifier will be a good amp to power my subs on the back of my 2001 Mustang?
Sony XM-2252HX
RMS Power Output @ 14.4V (High Current)
225W x 2 @ 4 Ohms 225W x 2 @ 2 Ohms
300W x 2 @ 2 Ohms 300W x 2 @ 1 Ohm
600W x 1 @ 4 Ohms (bridged mono) 600W x 1 @ 2 Ohms (bridged mono
Username: Sixstar
Post Number: 38
Sony is not very good, and it will make your subs sound worse. How much would you be willing to spend on an amp?
Username: Joe718
Post Number: 89
not good at all
Username: Koz1031
Monticello, In United states
Post Number: 30
you are gonna have to custom make the box for those 12's. Mustangs just weren't made to take a 12 in sub. Their trunk is big enuff, but the tail end configuration makes it imposible to get the box in there. The only way I found to do it was to go single boxes, or build the box in the trunk. 10's are a much better choice for that car, as the box will fit alot easier. Other than that everything is a breeze. Everything but the door panels snap in, and there are only 2 screws holding the door panels on. The back seat can be a bear to get out, but it will come out, and the driver side kick panel is a little tough.
Username: Koz1031
Post Number: 31
Oh by the way stay away from SONY stuff.
