I am deciding between Infinity Kappa Perfects 6.1(6.5") and MB Quart RCE 268 (6x8). Which set would be better? Would it even be worth it to make the modifications of changing my 6x8 openings in the front of my car into 6.5" openings so that I could put the Kappa Perfects in there? Also whcih would be better Referance series 6.5" MB Quart speakers or the Kappa Perfects?
Yes, the 6.5" is worth it, and the Kappa Perfects are the better component set.
Doug
I'm going to get 1 pair of the Kappa Perfects 6.1 for the front of my car and just get the templates, do you think they will fit with the mounting depth and all? I have a 94 Mazda 626. And also could you recommend an amp to run to my speakers?
