Tempest Box help Jon Glass
nickkk
i am building a vented box for 2 tempests. I listen to rap, love spl but dont want to lose all sq. need to know box volume and tuning frequency. Thank you.
Username: Jonathan_f
GA USA
Post Number: 1205
3-4 cu ft to each, tuned to 30hz. Ideally I'd give them 4 cu ft each, but I know you probably have space restriction and it would be very hard to fit that box in a car.
nickkk
Acttually i am installing in a minivan so space is no issue
Username: Nickkk
Charlotte, NC US
Is 4 feet b4 driver displacement or will i need to compentsate for the displacement of the tempests??
GA USA
Post Number: 1212
4 feet net, you'll need to compensate for both the sub displacement and port volume.
