Wiring a remote wire
hey guys im a complete newb just got my subs and amp just wanta conect everything. where do you connect the remote wire to. amp to ????. thanks
Username: Jmloughrey
Farmington, CT
Post Number: 181
on the back of your headunit there is a wire that shouldnt be connected to anything, i beleive its Blue with a white line, connect your remote wire from your amp to that wire on the back of your headunit...this way your amp will know when to turn on
Username: Jessejames
NB, PA USA
Post Number: 106
you can run the wire right with your rca's, if your head unit came with a wireing diagram, use that, but it 'should' be blue with a white like, like jeff said. There will be a small delay between turn on of the head unit and turn on of the subs, but that's normal.
yep found it thanks guys
