...its a 15...its gonna move a good amount of air...plus the eclipse should be able to handle a desent amount of power, just make sure you put it in a desent box, dont buy some crappy box for it...get one thats to specs
What would the best position for my box be with a pair of Polk GNX 12"(4 ohm) running on a bazooka 750watt on a 2 ohm load. Right now i just have them pushed against my back seats facing the trunk. nothing is mounted, but i'm thinking of gettin a clarion pro 4 channel amp and mounting my stuff under plexi... i have a relativly small trunk. in a 4 door sedan. They sound real good right now. and they hit pretty hard, but I was just wondering if anyone had any suggestions on a better mounting position, or and Ideas on what i should do with the plexi and mounting... I know how n' all, i am just looking for interesting ideas! Thanks
what would you guys suggest power wise for a amp? budget is like 200-300 US.
also if i had a decent box and amp what would u guys think i could hit db wise?
Mason
I've got 2 Power Acoustik FUBR 15" subs. I can't decide weather to put one in a ported enclosure, or both in a sealed enclosure. I'm driving a 00 Grand AM GT. Anyone got any suggestions?
