Anonymous | Is the type e a good woofer? is it worth buying, my price range is not for the type r so im going for the type e. how many ohms is it? im only buying 1, does it give good bass? |
Gold Member Username: Jonathan_fGA USA Post Number: 1159 Registered: May-04 | Not all that great. What's your budget? I'd recommend an Adire Audio Shiva if your budget is around $125 (that includes shipping), or possibly Cerwin Vega V-Maxes or Kicker Comp VR's. |
Anonymous | But isnt alpine subs good? or is it that the type e model is not good? |
Anonymous | is MTX better or alpine type e better? which 1 should i get MTX is cheaper so im going for Mtx but im not shure. im looking for huge bass subwoofer somthing that would play loud bass. |
Bronze Member Username: DavenPost Number: 57 Registered: Jun-04 | Its hard to find a good spl speaker at that price range, but the Cerwin Vega-Maxes are pretty lound and arnt that much, that would be my pick. |
Anonymous | what about the alpine type s people? |
Gold Member Username: Jonathan_fGA USA Post Number: 1176 Registered: May-04 | Alpine subs in general aren't that great. It sounds like you're looking in Circuit City or something. What's your budget? The subs I listed above are way better than Alpine Type e, or the type s for that matter. |
Anonymous | my price range is around 50-60 im willing to look on ebay as well. |
Anonymous | KICKER IMPULSE 15", is that a good woofer to buy i can get it at around $40 |
Gold Member Username: Jonathan_fGA USA Post Number: 1181 Registered: May-04 | You may want to consider saving more money, but look on ebay for the V-Maxes or Comp VR's. |
Bronze Member Username: CaraudiofngHouston, TX Post Number: 72 Registered: Aug-04 | Anon, Check out this post https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=4&post=125076#POST125076 FNG |
