New member Username: JonrobinsonPost Number: 1 Registered: Aug-04 | Hey I am new here and I have a fosgate 800a4 amp and 2 mtx6000 10s and i need to know how if possible to wire two 12 ohm subs into a 4 ohm load to the amp. Thanks guys. I dont want to have to buy new speakers if its possible. |
Bronze Member Username: JtbPost Number: 47 Registered: Jun-04 | 12 ohm subs??? anyways go here to figure out your options http://www.rockfordfosgate.com/rftech/wiringwizard.asp |
New member Username: JonrobinsonPost Number: 2 Registered: Aug-04 | Thanks but the highest impidence on the fosgate site was 8 ohm, my mtx thunder 6000 are 12 ohm, when i bought them they came in a box of 3 wired up into a 4 ohm load, i just cant figure out how to wire two of them into a 4 ohm load. Thanks guys!!! |
Silver Member Username: Davids2004Houston, TX USA Post Number: 527 Registered: Jun-04 | You cant do two of them thats why they sell them in 3's. |
New member Username: JonrobinsonPost Number: 3 Registered: Aug-04 | So its impossible? Thanks guys |
