Unregistered guest | I'm planning to buy a 10" for my 95 toyota truck, but am having trouble with the box specs. So far its just trial and error. can anyone help? also, is DHD a good brand for amps and subs, i found a site that will sell me an 800w amp and a 500w max 10" sub for about $150, but they're not a package. Is this a good bargain? I only have a budget of about $300-$350. |
Anonymous | DHD is not good. |
Silver Member Username: JmloughreyFarmington, CT Post Number: 124 Registered: Jul-04 | you can find much better for a single 10 and amp with a total of 350, try www.millionbuy.com they have really good deals on some products, as well as amazing deals on Boxes. |
Unregistered guest | what are some good brands of amps and subs? LIke i said, i only have $300-$350 to spend. |
Bronze Member Username: InsearchofbassPost Number: 64 Registered: Jun-04 | kicker comp cvr 12 4s with two it would be = 165 they are dual 4 ohm http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777&item=5714011291&rd= 1 clif designs = 145 + 30 shipping =175 .... 800 watt rms with subsonic filters and all 14.4 at 1 ohm http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797&item=5715483828&rd= 1&ssPageName=WDVW total= 340 thanks, in search of bass |
chasers Unregistered guest | thanks sean |
Bronze Member Username: InsearchofbassPost Number: 71 Registered: Jun-04 | your welcome let me know how hard it hits when your done. thanks, in search of bass |
