4x6 Speakers? Worth it to replace?
Billyyyyyyyy
Hi all, has anyone bothered to replace front dash 4x6 speakers? I have replaced my factory 6.5 with Infinity componants, which are amped by a 4 channel amp, and am going to replace the factory head unit, and then get some 6x9 for the other two channels on the amp. I have 4x6 speakers on the dash and am thinking about running those on head unit power, maybe the Infinity Kappa plates? Would they sound decent or not worth the 65 bucks as they are pretty small?
Username: Jonathan_f
GA USA
Post Number: 1154
Not worty it if you already have components. Dash speakers, especially factory mounted up firing ones, have terrible resonance due to the windshield, and poor stereo separation.
Billyyyyyyyy
Yeah I figured the same just wanted a second opinion, thanks Jon
