I just went out to buy a power wire for my Alpine MRV-100M and now I am wondering if this is going to be big enough to get the full power I can from my amp, the kit I bought has 17 feet of 10 Gauge wire in it and to me it kind of looked somewhat small compared to some other setups I have seen, mind you this isn't an extremely big amp by no means.So I was just wondering if I could get a few suggestions on if this is good enough or should I go bigger or maybe even smaller? .BTW I am going to be running Two 10" Clarion subs off this amp if that helps at all.All coments are welcome.Thanks
use 8 gauge to be on the safe side. i have a saying thicker is always better, plus you never know when you might want to upgrade, so you can save the time an effort y going thicker one time.
well 8g isn't that expensive, so i'd go with that, because if you don't have big enough cable you can start a fire by running too much power through it...
big cable is like a c0nd0m... it's better to have it and not need it, than to need it and not have it... ya know? Better safe than sorry.
