ok, just set up the sub the way you normaly would, then when its all set up, put the positive wire on your amp, into the negitive terminal, and visa versa...
The reason for this is sence the speker is inverted, it makes the cone move the opposite way it would normaly. If you dont do this, it will sound like crap.
