How to tell rms?
Username: Aaronlogan
Ontario Canada
Post Number: 7
Could anyone tell me how to tell the RMS on an amp? does it say anywhere? Please let me know!
Username: Caraudiofng
Houston, TX
Post Number: 23
What brand/model amp do you have? Someone here can figure it out with that.
FNG
Username: Pat_l
Tucson, AZ USA
Post Number: 454
it really depends on the AMP. But usually you can get a pretty good estimate by diviting the Max power which is usually put on the front and divide that by 2. For instance a 1400W amp would be around 700W RMS. BUT, this is just an estimate. Companies like Sony, pioneer, Audiobahn, ect will over-rate there amps. So a Sony 1400W is most likey about 3to 400W RMS. But compines like JL, RF, and others under rate for example a 2400W Rockford AMP is probably putting out about 900W RMS insted of 800W.
Username: Fryguy
Barrington Passage, Nova Scotia Canada
Post Number: 51
I got a good article on power and more on my forum here http://fryguy.ca/Forum/viewtopic.php?p=5#5 basicly RMS is, peak_power X 0.707 = RMS.
