yea thats a good amp, at 75% its a little less efficient than one would like to see out of a class D amp but its still infinitely better than an a/b, especially if youre running it at a 1 ohm load. The amp is good, but only as good as what it is running (plus I hope you have a capacitor cause 1800w constant is a battery drain). So what kind of subs/speakers are you running with that?
u wont need a cap...what you will need is a bigger alt!!!
what size fuse does the amp have??? i would bet $100 to a donut that power acoustik 2400w amp wont put out 1800 RMS.
It's a 30 amp fuse, but there are 4 fuses connected to the side of the amp.So would that be 1200 watts instead?I'm really new to this, thanks for the feedback.
