Does 1800 sound like too much for this equipment?
Username: Lawrence528i
New York, NY United States
I used to have this set up in my car:
Clarion 7" VRX935VD Touch Screen Head Unit
1 Rockford Fosgate Amp 801X
1 Rockford Fosgate Amps 1001bd
2 Diamond Audio M6 5.25 Mid Components
2 Beymas Rear 6.5
2 12" Kicker L7 with ported box :-)
this is how much room i had before
but my car was totalled and I removed everything from the car, and I've decided to go with a different set up.. I still have my subs in the box, but that box too up way too much space.. I mean the kickers hit really hard and I got no distortion from them whatsoever, but the space was an issue for me..
Now that you've got the history, heres the main topic.
Sound System
Memphis - HPO-124D or M3124D (300.00)
MEMPHIS 15-MCSQ5.25 5 1/4 (300.00)
Radio Install (200.00)
Custom Made Box Plexiglass (500.00)
Amp Rack (200.00)
Labor (200.00)
Total 1700 - 1800
I received this quote from Speedworld in Queens, NY, maybe someone here's heard of them? What do you guys think? Am I being overcharged or what? I mean I can save maybe like 2 - 4 hundred by buying the items online, but then I get no warranty from Memphis..
If anyone has any suggestions on what kind of set up i should go with, I'm open to all suggestions in a price range of about 800-1500
I'll be keeping my two amps and head unit, if anyone is interested in two kicker L7's in a ported box let me know, and I'll take the measurements for you. They didn't get completely messed up but the diamonds have some dented scratches on the cone, oh and they were only working with one crossover, because one of the them blew.. Upload
Username: Joe718
Post Number: 59
man i live in brooklyn an i have seen speedworlds work its ok but you might want to go to a shop called Gran Turismo in woodhaven its on atlantic avenue. they know what there doing. you might have seen there work b4. therss a shop on queens blvd with a truck that they did the install on. its a red navigator with 6 15 l7 solobarics thats hitting in the 180's in spl, thats there work and there cars are in all the local maazines likie plush. plus they are memphis and jl audio authorized dealers my freind just had his car done up with memphis mojo amps and subs. heres the address 79-19 atlantic avenue woodhaven ny 11421 just ask for a guy named rick.
how much did they charge your friend for the set up?.. what do you think about the price for the equipment and install? i'ma go check that place out tomorrow
Username: Joe718
Post Number: 61
well he had his doors done over with and 8 inch, 6 inch and a tweeter in each door and 4 8 inch mids in the rear deck, he had alot of work done, your system shoulndt run you that much, it might be a good bit less than what you expected. they will work a good price out for you. Get back to me and let me know what happend.
I went today and spoke to Manny? i think that was his name, and those guys are more expensive than speedworld.. They gave me a quote of 2000, for the purchase of two memphis component speakers, custom made plexiglass box, and installation of radio, amps etc..i guess i'll keep shopping around
Username: Joe718
Post Number: 63
ok man. good luck
