JL W7 , IS this amp enough?
Username: Lilfloyd
I have a 12w7, and East Hamilton radio Hooked me up with a Phoenix gold octane R 15.0:1 Class d Mono Amp, 1500 watts max.. Is it enough for this sub? Here are the specs.....
18dB varia1500W x 1 (2 ohm mono) max power subsonic filter
18dB variable LP crossover
Dimensions: 14.5L x 10.875W x 2.25H
Low Pass Level port
Thanks!
Username: Jessejames
NB, PA USA
Now... I don't know i ton about JL 12w7's but that does sound like it should run the sub well, as long is it is just 1 sub, because i think that those are dule voice coil, and that would bring the ohms too low for that amp, but if you are just running one sub, it should work.
Username: Jonathan_f
GA USA
Post Number: 1113
That amp is actually 1000W RMS at 2 ohms, 500W RMS at 4 ohms. The 12W7 is a single voice coil 3 ohm sub, and that amp is right on target for a 12W7 as it will put out 750W RMS@ 3 ohms. The only W7 that's DVC is the 13W7, it's a dual 1.5 ohm sub.
