I just purchased a Definitive Procinema 60 HTS and now I need expert advice on which receiver to use with it so as to bring out the best quality in the ProCinema 60. The speakers will be used for mostly movies. Thanks for the advice.
Thank you for your advice. What about the Marantz SR 4400? Do you think that would do the job as well? At the dealership for Definitive, they were using Onkyo TX-SR501 for their Procinema 60. I just don't know if that was good enough.
