Unregistered guest | My audio from my laptop, when hooked up via a USB 2.0 cable to the 55txi, the audio cuts ins and out during playback. Per Pioneer support, I got a new cable and also downloaded the latest driver for my laptop's sound card. Still cuts out. Anyone else out there have the same problem and able to fix it? Please let me know. Thanks. Mike. mkcruz@bellsouth.net. |
Gold Member Username: Project6Post Number: 1131 Registered: Dec-03 | are you playing back mp3s? If you have a lot of other programs running in the background, this will cause your music cut in and out. |
MikeCruz Unregistered guest | Yes, mp3s playing back using the iTunes software on my PC. I've had only iTunes open and the audio still cuts in and out. |
