Anonymous | I've been thinking about a MTX 7500 series 12 I've got an AMP that push's 500w RMS bridged and 200w x 2 channels a 2 ohms. Anyone suggest a single 12 or dual 10/12 setup that could work. I'd like to keep it under $400 for subs and box. Also, anyone looking for a Polk DB10 in good working order? Comes with 1.2 cub. ft. sealed box |
Bronze Member Username: JtbPost Number: 41 Registered: Jun-04 | Two cerwin vega Vmax, $100 a piece, 300 rms I piece I believe, but 200 to each would be fine. With shipping that would leave you about $150 for box, wires, installation if you want to pay. |
Anonymous | Thanks John. is $150 a reasonable amount for dual 12 box? |
Silver Member Username: JmloughreyFarmington, CT Post Number: 106 Registered: Jul-04 | for a little more you can get a dual 12 box from subzone...i beleive the website is www.subzoneusa.com they supposidly make some of the best boxes, or try www.proboxrocks.com |
Bronze Member Username: BoopersLima, Ohio United states Post Number: 55 Registered: Jul-04 | I still like my shocker (12" 2ohm dvc) in a slot ported box for 350.... see is you can find shocker audio |
