8 ohm front speakers
Username: Balderdash1
Hi,
I'm opting to go with 8 ohm tweet/mids up front. How should I wire these to the amp to get the best performance?
Thanks,
Balderdash1
Username: Mattl
Bolingbrook, Illinois USA
Post Number: 372
Note that you can wire these in parallel to get 4 ohms, but they'll always sound too bright because the tweeter will be drawing as much power as the mids.
-Matt
Username: Jonathan_f
GA USA
Post Number: 1076
Not if he's using a crossover. If the tweeters are on high pass and the mids are low pass, then the amp will see the load as one speaker, a final 8 ohm load. You'll need an amp that puts out twice as much as the required RMS for those speakers at 4 ohms (if your speakers are rated for 100W RMS, you'll need an amp that's 200W @ 4 ohm).
Username: Mattl
Post Number: 376
Yeah, s'why I only said "parallel"... Those are really in-the-home components.
-Matt
