Amp keeps cutting in and out
helphelphelpporfavor
hey can someon please tell me what is wrong with my amp and what I need to do to fix it, I am so frusturated. I have a coustic 401 se amp with two 12" MTX subs on it, and it keeps cutting in and out. The pwr/prt light is stays red for like 10 sconds the turns green for a second and works. Help Please. I don't realy know much about amps so might need to be pretty specific. sorry. thanks
Juicy J
yo man.. your subs is just takin to much power from your amp..to help smooth things out you should get a 1.0 flud. capaciter.you need to find out what your subs rms power is..and see if your amp is the right one fo it.i suggest if your subs are 400rms...then your amp should push 400watts at 4ohm's
