Too cheap for a ported box made to specs, what should I get for a sealed box?
Username: Invain
Post Number: 17
I would like to get a slot ported box for my sub, but I dont' want to spend a lot. What do you recommend I get for a sealed box, or will it not sound nearly as good? I have a audiobahn AW1200Q, it may not be the best for sq, or very good at all, but I got it dirt cheap. So would a sealed box be fine?
Username: Sploosh56
Post Number: 338
did you look on ebay for slot ported boxes?
Username: Invain
Post Number: 19
yeah, and there's nothing that's around 3 cubic feet. Everything is too small.
Username: Sploosh56
Post Number: 341
Maybe try and build it yourself?
http://www.crutchfieldadvisor.com/S-YtPdr1HMyjg/reviews/20030701/build_box.html
This should help you out
Username: Invain
Post Number: 23
Thanks Whal, that site has great instructions.
