I am going to buy a sound level meter from Radio Shack. I noticed that they also sell digital meters. Which one should I buy, the digital or the analog? Is one easier to use when calibrating my system? Is one more accurate than the other? Thanks for any advice you have.
J. Vigne
Buy them both, then you can decide and tell us. Afterwards sell one on ebay for tremendous amounts of money and go live in the Bahamas. Really, it doesn't matter which you buy. It isn't even that important to have one. Borrow one from a friend or store, their not using their's I'll bet.
