Alpine Type R subs
Username: Trancein305
Hialeaj, Fl Usa
Hey im a rookie at this but i need help. i just bought 2 type R's 12" 4 Ohm 1000 watt subwoofers.
I also bought 2 amps. one of them is a RF Fosgate
301s
75 W X 2 @ 4 Ohms RMS
150 W X 2 @ 2 Ohms RMS
300 W X 1 @ 4 Ohms Bridged RMS
900 Watts Peak/Max
SONY XM-2252HX
225Wx2 Ch, 4 or 1 Ohms at 0.04% THD
325Wx2 Ch, 2 Ohms at 0.08% THD
650Wx1 Ch, 4 Ohms at 0.08% THD
I plan to use the sony amp to power the 2 12's. I have a 2001 stang with stock speakers rear and front so i dont know if i should use the RF amp to power the rear speakers but i thinks thats to much power for the stock rear speakers? i plan to upgrade them with more powerfull one's but in the mean time what do you guys think about the combination to power the speakers is it good or bad? please help.
