Need wiring scheme for alpine 3442
Please and thank you!
Jeramy
Yellow- Constant
Red- Switched
Black- Ground
White- Left Front +
White/Black-Left Front -
Gray- Right Front +
Gray/Black-Right Front -
Purple- Right Rear +
Purple/Black- Right Rear -
Green- Left Rear +
Green/Black- Left Rear -
Blue/White- Amp Turn-on
Blue- Power antenna
Orange-Illumination
Orange/White- Dimmer
Your car may mor may not need all of these wires I STRONGLY suggest getting a wiring harness from a local stereo shop and NOT cutting your factory wiring it will only cause headaches in the long run, these are only the colors for the deck and they are universal as adopted by CEA the harness you buy will also have these colors so it will be as simple as matching colors
